I have printed successfully on the Ultimaker 3 Extended using Cura but this is the 1st time that I am trying to use S3D generated gcode since I really dislike Cura. I started with the S3D machine configuration and I then defined the two filaments and their temperatures and set the left extruder as the primary extruder and the right extruder for support. When I start the print I run immediately into issues, all on the 1st layer:
When starting to print the prime pillar the extruder starts hitting the bed very fast and it sounds like a woodpecker.
Then it moves on to start printing the actual object's 1st layer and it prints it in the air. The extruder stays 2-3 mm above the print bed and extrudes while moving as if it is trying to print.
I wonder if the issue is caused by the prime pillar.
At this point I aborted the print since there was no sense in continuing.
I have attached the factory file in case it helps.
and the gcode file (zipped due to size)
Any idea what the problem may be and what is the solution?
