wirlybird wrote:When you make the changes do you click the update button, I think it is update (not in front of it) to save the changes to that profile? I find when I pick PLA for instance and make adjustments and don't update they are discarded when I close out.
Another thing would be to delete the line for the layer setting where the fan comes on similar to how ABS is set up.
Been there done that. Saved several different versions all have the same issue. go to cooling after a print and it's set to come on after the first layer at 100%
