Hello.
The issue i am having is that i have a printer that has software endstops coded in at 300mmx x by 300mm y. The printer will not move past those endstops.
In simplify3D, i have the printer configured so that the bed size is 300mm x by 300mm y. HOWEVER, if i am jogging the printer, and i send the command to to to y=300 x=300, and then press plus 10mm on the jog controls, simplify3D will show my location as y=310 x =300, but my print head will not move. So, now if i press minus 10, simplify3D will show my location was y=300 x = 300, but my printer will move, causing its actual location to be y = 290 x = 300.
I know i won't be jogging the printer around too much and it doesn't affect printing, but this still rather annoying because when it happens i have to rehome the printer. Is there a way around this?
Thanks!
