audryhome
GCODE file naming vs Factory file naming
It is very annoying, when you saved your factory file and then produce a gcode file, not to have a default file name the same as factory file.
Usually, the file name is the current part, and this force user almost every time to overwrite this name.
Default GCODE Filename = Factory Filename?
