is there anyway to choose the support infill angle when you do manual support?
Appreciate the assist!!dkightley wrote:Just to clarify whirlybird's reply.......the angles of supports, either manual or automatically created, are defined in the Support Infill Angles box in the Support tab in the profile settings. You can define one or more angles by adding to the list in the table using the Add angle button and value field.
There are not different angle settings for manual and automatic supports.
