rincewind
Infill settings are the same for all quality presets
I want to adjust infill settings based on the print quality. However, if I change Infill extrusion width (or anything else) for the 0,05 preset, it will change every other preset as well (0.35, 0,2 etc.). I want to have different infill settings depending on the layer height/print quality. The only thing that can be changed between the presets is the infill percentage.
brian442
Re: Infill settings are the same for all quality presets
There's lots of threads on the forum about how to do this. Go to File > Export FFF Profile, open that file in a text editor, and add the <infillExtrusionWidthPercentage> tag into each <autoConfigureQuality> section. Then save and re-import.
