I've searched the forum for a definitive answer for this and have found both possible answers; which didn't help terribly...
I have a print which has three processes, these are to vary extruder and infill percentage. I want also to have different bed temperatures, but not related to the processes but to the absolute layer.
I know that I can specify temperature by layer but is that the layer count for each process, or for the print as a whole? I can see pros and cons for each possibility so the answer isn't immediately obvious.
So, if I specify a temperature of 110C for layer 1 and 100C for layer 2 in the first process, what happens 8mm later when process 3 starts? I can see that the temperature settings aren't duplicated (which makes sense if I want to have different temperatures by process). This is further complicated by the fact that process 2 is a different extruder printing text within the vertical limits of process 1, so layers of process 2 occur at the same height as layers of process 1.
Can someone explain this definitively?
