There are a few modification I have made to my printer, Some are preset up routines that need to be run prior to the hot end firing up and a couple need to be run after a print has finished. There is an option for custom G-Code to be added after the print has finished and you can run a script before the print starts but it seems that you can not set a custom script to run before the hot end and heat bed is started.
Is there any way to create or modify the startup of the printer to allow for these functions to be inserted? What would be awesome is the ability to actually write a kind of custom post processor and be able to alter the advanced functions beyond what can currently be done in the printer setup.
