Hello!
I believe this feature should be included ASAP. It is awful for the ones that we have 3D printers with the IDEX system (each extruder travelling and working independently, letting the inactive one in a rest-place), to NOT BEING ABLE to set up different cooling settings per each extruder.
This put a critical limit to the use of this IDEX system as you can't combine different materials propperly.
For example: if you want to combine ABS and PLA in the same part with IDEX system, you can't do that because you are forced to set up the cooling settings for one of them. Everyone knows the big difference in the fan speed settings between ABS and PLA, so being unable to set it up differently per each extruder makes it impossible to use both materials in the same print regardless having the IDEX system.
Please change the "Cooling Tab" so it works more likely the "Temperature Tab" in which you can set up different settings per each extruder.
Thank you!
