Running the most up to date version of Simplify3D in my OSX, i have been running into the problem that in preview mode the entire part in an uniform color when the coloring is set to movement Speed.
I have changed my preference to mm/s, and the coloring range is from 15mm/s to 1666.6 mm/s, I know I do not have the vastest printer out there but my CoreXY does obviously not come even close to that kind of speeds.
Is there a way to change the coloring range so i can make out which paths are printed faster than others?
If not, could this be added/ updated to a more reasonable coloring range?
Cheers
