I just receive the last model from Josef Prusa, the Prusa I3 MK3, an awesome product working well with his own slicer (named Slic3r), but this software is having a real poor render than S3D, then I've try to use S3D (as usual with Prusa I3 MK2S) but this time every print i've try to made witf a raft is crashing after the first layer:
As you can see in screen this appear to be linked with fan.
I'm not an expert with gcodes, so here are the two gcodes for the same sliced 3d object.
Gcode generated by Slic3r (working well) : https://puu.sh/yQh0L/7e62b4afc4.gcode
Gcode generated by S3D (crash on 2nd layer) : https://puu.sh/yQh2z/29413aa1b7.gcode
I can made some try if a developper would try to fix it
Thanks for your help.
