[extruder0_temperature]
[extruder1_temperature]
[bed0_temperature]I have it checked off, as my M103 command is just the first layer temperature.horst.w wrote:I'm not sure if this is relevant, but in the Tab GCode of the Settings Window exists an option "Include M101, M102, M103 Commands"
Do you have checked ON or OFF this box?
DarthRevan wrote:Again, if the software doesn't see these variables and has temperature set points for layer 1 in any of it's temperature controllers you'll see automated commands get inserted by S3D. So these are most valuable for specifying the order of all operations before your print begins. If you don't need to specify the order, the automated commands work great!
