mark_3d
Feature Request: Linear Advance
Is it possible to insert a beahavior like the linear advance used in marlin firmware that will give the print a little bit more quality?
rrdavis
Re: Feature Request: Linear Advance
I have used this in the past. From what I remember, I just had to add a "M900 K30" command in the starting script and make sure it was enabled in my firmware.
blackbird2016
Rrdavis is right.
Given your printers firmware supports linear advance (Prusa e.g.)
Just add the M900 Kxx command in to the start script where xx will be your k for any given material.
mark_3d
How to ceck if it's enabled in my firmware? i have a Rasie3d N2 duale Extruder.
rrdavis
Try asking the manufacturer
zemlin
mark_3d wrote:How to ceck if it's enabled in my firmware? i have a Rasie3d N2 duale Extruder.
The firmware currently published by RAISE does not have Linear Advance enabled, but users have posted firmware on the RAISE forum.
http://forum.raise3d.com/viewtopic.php?f=3&t=6244
SDX
Linear Advance would be very difficult to implement within a slicer-software. It would at least double your g-code.
★★★★ SDX ★★★★
wbarber69
SDX wrote: ↑Tue Feb 27, 2018 12:09 pm Linear Advance would be very difficult to implement within a slicer-software. It would at least double your g-code.
Craftware does it. quite well, and doesnt need the firmware to support it
arhi
wbarber69 wrote: ↑Sun Mar 11, 2018 11:10 am
you sure it's the same thing?
Embed M117 codes into G-Code
open source and unlicence
Omikron
Looking through the posts I didn't see if this feature was acknowledged as planned for next release (whenever that may be) but +1 for per-material LA settings. Every other slicer I use has it, and it's lack is one of the reasons I don't use S3D as often anymore.
