Also, I attempted to do an extruder calibration. I marked the filament at the base of the extruder and measured out 150mm and marked it there. I sent a command to extrude 100mm of filament at 30 mm/s, and after measuring, it extruded about 96.5mm. So it is underextruding a bit? From what I have been reading, I need to change the extruder steps per mm, but I have no idea how to do that. Would anybody know how I would go about that?
As for the optimal temperature, I will be trying that and will get back to you once I figure that out, as well as measurements from the thermometer. I really appreciate all the help you guys have been giving me. Some people also recommend I do the whole 20mm cube measurement and change the offsets until it measures exactly 20mm with a caliper. Is this a good idea? I wont lie, this has become somewhat frustrating, but I won't give up until I figure all of this out.
