Could it be layer width? Currently set at auto .48 and 100 extrusion multiplier.
Perhaps print inside out versus outside in?
Any help appreciated.
account deletion
This layer happens very late in the print on an overhang. The rest of the print is perfect so I am thinking the flow is OK?airscapes wrote: ↑Tue May 22, 2018 4:23 pm As I sit here peeling the perimeter off a print i stopped 3 layers in due to underestimation.. That could be you issue as well.. If your filament has changed diameter you may need to re calibrate.. In my case I just needed extrude a couple hundred mm of plastic while wiping the nozzle to remove whatever was in there reducing the flow..
That's a great suggestion but it's not really the top layers, it's the perimeter layers which occur for a far longer time and distance than simply the top layers. The top layers seem to print fine but I will not ignore your suggestion. Maybe dropping the outline speed will serve the same purpose as your suggestion? Trying everything.
