So... I've been printing some pretty complex parts. They have support material on the inside, outside, and ABS little parts all over...
anyway, things are going pretty well, but I'm curious about one thing.
Makerware has this option to print a purge wall on the side so that it can keep the ooze from collection on the model. Typically you see this when one extruder is idle for a while while the other is printing its stuff. Then when you switch you get a glob of material wherever you start.
Question is.. what do you do? Switch back to makerware? I've finally got things tuned pretty well in S3D it seems.
