TomOH
Re: Simplify3D Won't Launch Properly
Seems to be an old problem, but after 2 years of using it (W7-64), the exact same problem. It will not start. Process is running, but nothing is being displayed. No error in the event log either. I wonder if that is their crappy licensing server that times out and never responds to requests?
Maury-Bs
Same problem for me, sometimes it starts in a couple of seconds and sometimes it takes up to five minutes.
Already opened firewall and reset options but no results.
It's unbelivable for a commercial version :(
mthompson239
Win7-64 24gb i7-4200MQ
Windows FW disabled
No blocking via Sophos EndPoint
Last Win update 2 days ago
S3D 4.0.1 per running in task manager...but not opening.
No LAN or local conditions have changed
Just started tonight not opening.....not good for when I use this software for my business on multiple times daily...
I can load 3 sessions of AD Inventor before it...ah wait, it doesnt even open. :mad:
Luck I just recently exported all my profiles. Will try to uninstall and reinstall tomorrow and see where im at. If still not proper, I will open a ticket unless anyone has any other ideas to assist.
I seem to remember a thread discussing S3D taking a while to load.....and I believe the solution was to open the Machine Control Panel and empty the list of entries in the gcode library list.
That does seem to help a bit. Loads back up pretty quick though!!
mthompson239
Since I had my very recent FFF files, I uninstalled, deleted reg keys, and del %user% folder noted in the above, rebooted, downloaded S3D again, and was able to reimport my FFF and runs proper now.
mthompson239
dkightley wrote: Tue Sep 11, 2018 3:25 am I seem to remember a thread discussing S3D taking a while to load.....and I believe the solution was to open the Machine Control Panel and empty the list of entries in the gcode library list.
I guess this would be a method as well if the application would have been able to open.
