vendramini.br
Gradient color printing code
I have a ZMorph equipped with DualPro Toolhead where it's possible to mix colors along printing process via Voxelizer (an example you can see as attachment).
I'd like to have this feature at Simplify3D.
All the best!
Marcelo
http://www.otto3d.com.br
3dunique
Re: Gradient color printing code
I Need this solution too.
I'm using the Simplify3D only with single extruder, with Dual Pro I have to use the Voxelizer, but it's not the same quality like Simplify3D.
@Simplify team, do you have something on roadmap about this?
Regards,
Carlos
Thanks for the feature request! We've experimented with color mixing quite a bit here in our office. Can you share more about the specifics you'd want here? Are you requesting color be interpreted from the model files or are you wanting to manually specify color information for the print file?
