Yesterday, I needed to print 27 of the same small objects one after the other. To do that I had to drag and drop the stl file into the software 27 times. Then I had to create 27 processes, and then associate each process in turn with the 27 objects on the bed. I used the Center and arrange button to center and arrange the components. After exporting the job and starting the print, the first 2 went down fine. I use and Anet A8 and the clearance I selected was 5mm. As is turns out, by the time the 4th object needed to be printed, the nozzle of the printer impacted the 3rd object and caused the object to stick to it. The distance between the objects in the y direction was less than the width of the nozzle
Can we have an option that causes the center and arrange function to keep the objects further way from each other by some distance (which I've taken to call the keep out range).
