laborda
BUG - Separate Connected Surfaces.
I'm having an issue with this command since the first update of 4 version.
Simplify divides in more parts than expected, and you end with lots of empty models apart from the actual models with polygons.
Am I the only one with this problem?
Thanks,
Joaquín
Re: BUG - Separate Connected Surfaces.
This would generally mean that there are issues with the model that need to be corrected. Run the model through a fixer such as Netfabb or makeprintable.com and see if it helps.
laborda
Thanks wirlybird, apparently you are right, I made a quick fix in Netfabb with one of the problematic models and the issue disappears.
I also though that this issue may mean something wrong with the geometry, but whats strange for me is that in previous versions with the same files this doesn't happen. On the other hand if I export the parts one by one they load and print without problems.
