AndersE
Autoconfigure materials.
I am having problems with this.
Settings i do for one material transfers to all other materials. *NONE* seems to save for specific materials.
So what is the meaning of having this "feature" when the settings are not saved per material?
Same on 4.1.1. as 4.01 and 4.0.0
Am i doing something wrong?
On my other machine i got so tired of it so i made new PROFILES instead for every material.
Some settings saves, like those in ooze control for example.
Re: Autoconfigure materials.
Changing material and quality specific settings is explained in-depth here: viewtopic.php?f=8&t=5977&p=25950#p25947
JE Designs
I also noticed an issue with the materials tab .
I tried to custom configure a profile for a flexible material I was using and adjusted all the settings to what was needed , when I set the bed and extruder temp and saved it , I loaded a project and set it using this saved material profile and it now crashes and resets my printer ???
The only way I can use it is to use the basic PLA profile and just switch the parameters over to what I need , If you tweak anything in the temperature tab it causes a crash so I just adjust the temps during the heat up stage .
Changing temperature set points for PLA material configurations has worked for me countless times. Can you describe in further detail a sequence of steps I can follow to reproduce this issue? What profile are you starting from. What specific clicks and changes do you make before the crash occurs?
