dotty
Problems with 4.1, now reverting to 4.00
The new version cannot generate the GCode for my print. Luckily I had the older version because it works.
Attached is the file so you can figure out what's causing 4.1 to get stuck.
PortableCartTopBottomRev9.STL
(592.95 KiB) Downloaded 292 times
S3D-Alex
Re: Problems with 4.1, now reverting to 4.00
We were able to slice this in 4.1 successfully. Can you please post the Factory File for this issue?
Slices for me as well in v4.1
dotty
Rotate is using -90 for x like this:
Does it still work?
mroek
Slices fine for me in 4.1.1 after rotating -90 in X.
dotty
Ok, I couldn't when it was rotated but could when it wasn't.
Attached is the factory file from 4.0
PortableCartTopBottomRev9.factory
(231.9 KiB) Downloaded 314 times
mroek
Your factory file does't slice for me either. S3D just appears to hang at "Finding overhangs" while keeping the CPU busy at 100%. Pressing cancel doesn't work, and if S3D is closed (by pressing the X in the upper right hand corner), the window disappears as if it closes, but S3D leaves a process running, so to actually end it you need to kill the process.
