echo mtools_skip_check=1 >> ~/.mtoolsrc
sudo umount /dev/sdc1
sudo mlabel -i /dev/sdc1 -s ::MYNAMECode: Select all
ln -s /media/USERNAME/MYNAME ~/MYNAMEI am a Windows user. How does this help me?dhylands wrote:As a workaround, you could create a symlink.
You can also label your sdcards. Under ubuntu 14.04, I did this:(assuming that your sdcard is /dev/sdc1). Then the sdcard shows up as /media/username/MYNAMECode: Select all
echo mtools_skip_check=1 >> ~/.mtoolsrc sudo umount /dev/sdc1 sudo mlabel -i /dev/sdc1 -s ::MYNAME
You could then create a symlink from your home directory to the media directory:If you name your symlinks with appropriate leading character, then they would even show up at the beginning of the list.Code: Select all
I would prefer having an option in S3D.dhylands wrote:In Windows, you can create shortccuts.
