jgwinner
Spiral Floor
Is there any way to print the floor of a vase mode object with anything other than the flat horizontal lines? I'm printing a clear disk and would like a slightly more artistic pattern than a circle with some lines in the interior.
I've thought of doing 100% infill but maybe didn't get the way to make it really 100% ... there seems to be tiny gaps in all of the patterns, but I haven't tried printing.
My object is essentially a solid disk with a lip ... I don't see why the print head couldn't start at 0 and smoothly spiral out, but it seems like the first layer is always an (ugly) filled in circle.
Any ideas or other software?
Thank you,
== John ==
zemlin
Re: Spiral Floor
Don't have S3D handy, but look at Solid Infill - linear or concentric. Try concentric. It won't spiral out - it will be concentric rings, but that's closer to what you want.
jgwinner
Re: Spiral Floor
Thank you!
Looks like it was "external fill pattern" under Infill, which I have to admit I didn't know what was :)
It would be great if it could go 'out' as I'll get a drip (I'm using a really big nozzle, .8mm or 1.2mm), but the spiral in at least works!
It seems like if I have a hole in the center it has to draw into the middle, which is a shame.
Thanks for the tip, I can work with this!
== John ==
Brehmer
Re: Spiral Floor
jgwinner wrote: ↑Wed Apr 03, 2019 1:20 pm Thank you!
== John ==
Hey John, it would be great if you reported back when you get this done and talk about your experience. I'd love to get a more artistic pattern going too and I don't know how to accomplish that.
