I had a lot of issues with the retraction during the changing tool process since the beginning of Simplify 3D. I was very happy with the new 4.1 wich the issue was fixed ! But since the 4.1.2 I have the issue again.
My trouble is that the tool changing process is impacted (outside the script) regarding if I had a script or not.
My script :
{IF NEWTOOL=0} T0 ;Start tool switch 0
{IF NEWTOOL=0} G1 X[next_position_x] Y[next_position_y] F[travel_speed] ; move to next printing location
{IF NEWTOOL=0} G1 Z[next_position_z] F1002
{IF NEWTOOL=0} G1 E0 F[toolchange_retract_speed] ; prime new tool
{IF NEWTOOL=1} T1 ;Start tool switch 1
{IF NEWTOOL=1} G1 X[next_position_x] Y[next_position_y] F[travel_speed] ; move to next printing location
{IF NEWTOOL=1} G1 Z[next_position_z] F1002
{IF NEWTOOL=1} G1 E0 F[toolchange_retract_speed] ; prime new tool
G92 E0Bellow, this is the tool changing process before printing the skirt without custom tool change script :
G1 X109.975 Y103.499 E3.2314
G92 E0.0000
G1 E-20.0000 F2400
T1
G1 Z0.325 F1002
G1 X121.620 Y107.556 F12000
G1 Z0.125 F1002
G92 E0.0000
G1 X123.620 Y109.556 E0.0279 F2100Result : The nozzle is not correctly feed.
Now, the same process with a custom tool change script :
G92 E0.0000
G1 X121.620 Y107.556 F12000 ; move to next printing location
G1 Z0.125 F1002
G1 E0 F2400 ; prime new tool
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G92 E0.0000
Result : Without unretract at the end of the previous tool caused oozing and a nozzle not correctly feeded too.
Yes, I could add a retraction into my script, but you will see that I have an other issue...
Now the tool changing process of each layer (just before printing the prime tower) without custom tool change script :
1 X85.218 Y147.995 F2100
G1 X85.213 Y147.990
G92 E0.0000
G1 E-20.0000 F2400
T1
; feature prime pillar
G1 Z0.325 F1002
G1 X118.807 Y191.097 F12000
G1 Z0.125 F1002
G1 E0.2000 F2400
G92 E0.0000
G1 X118.807 Y200.617 E0.0940 F2100Results : OK
And the same with a custom tool change script :
G1 X85.218 Y147.995 F2100
G1 X85.213 Y147.990
G92 E0.0000
G1 X118.807 Y191.097 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G1 E20.2000 F2400
G92 E0.0000
G1 X118.807 Y200.617 E0.0940 F2100Results : There is a very big over extrusion !
At the beginning of April with the 4.1.1 version, I was able to print well with custom script.
The Gcode before the skirt :
G1 X116.260 Y134.068 E1.2087
G92 E0.0000
G1 E-20.0000 F2400
G1 X116.094 Y134.468 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G92 E0.0000
G1 X117.094 Y135.468 E0.0105 F2100The Code for each layer :
G1 X110.023 Y153.211 F2100
G92 E0.0000
G1 E-20.0000 F2400
G1 X118.769 Y160.669 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 X111.178 Y154.196 F12000
G1 Z0.125 F1002
G1 E0.0000 F2400
G92 E0.0000
G1 X118.769 Y170.269 E0.0715 F2100
I hope that my English was not too bad, and you will able to help me...
PS : I have to use a custom script for 2 reasons :
1/ I unretract the T1 during my start script before printing with T0. And there is no unretraction of the T1 for the first use
2/ I delete on this exemples, but I made and extra priming process of the T1 (only) into a dirty box before to move to the next location.
