CerbereOrion
4.1.1 not working anymore with "curl" to send Gcode to Octoprint
Hi !
I just updated Simplify 3D to the latest 4.1.1 and i am experiencing problem.
With the previous version of S3D, i used the "curl" script to send my files wirelessly to Octoprint.
But it seems this trick does not work with the 4.1.1.
Any idea how i can get this feature back to work ? Or any other trick for that...
Thanks a lot !
Re: 4.1.1 not working anymore with "curl" to send Gcode to Octoprint
Can you share with me your script? (minus your API key) Are there spaces in any of the filepaths being used?
TylonHH
Same here. I use this scipt:
Code: Select all
curl -k -H "X-Api-Key: XXXXXXXXXXXXXX" -F "select=true" -F "print=false" -F "file=@[output_filepath]" "http://192.168.178.44:88/api/files/local"
The files has no spaces.
But in previous version this was no problem.
I use 4.1.2
EDIT: when I "curl" in windows cmd with the full filepath, it works.
arhi
use gcodestat :D
you have to add full path to program unless you put the file somewhere in global path (irrelevant if you use gcodestat or curl)
Embed M117 codes into G-Code
open source and unlicence
