dan
Missing Object
sometimes when i import a model and prepare it for print and then go back to import another model
and then again prepare for print, the second model is not being calculated to gcode.
I have to close the prgram and then do it again to see the results in "Prepare to print"
TenKOhms
Re: Missing Object
When you slice a model s3d associates models with their respective processes'. When you exit the preview mode and import another model it doesn't automatically get associated with processes', so you will have to open the FFF settings window, find the button that says "Select Models", and select the model you just imported.
tri-lite
Re: Missing Object
Since I frequently run into that same problem, I added an image so you can see where to find the buttons.
Double-click on your Process to open the FFF Settings window.
1. Click on the "Other" tab.
2. Click "Select Models" at the bottom.
3. Click "Select All" to make sure your process applies to all models.
dan
Re: Missing Object
thanks guys :)
