greybeard
Re: Ability to measure STLs, hole sizes, and bottom surface
I wrote an App to measure Any graphic for which only one dimension is known. The graphic can be an STL
The primary purpose at the time was to measure electronic parts but, it works for any graphic or 'whatever' on your monitor.
Example of using it in Simplify, below... CLICK on the video to open/view it
• Loaded the .STL into Simplify
• I know the width of the Part (see drawing image)
• Though also knowing the Dia of the large hole, the attached video shows using the App to confirm the Dia...
(I did not fuss with trying to get an exact dimension...)
The app is written in Java and requires Java8 (JRE 1.8) as minimum.
The app with use info is posted here
https://github.com/farTooOld/Woof
3D Print Parts
lazymaniac
+1 Measure tool could be really helpful :)
lazymaniac wrote: ↑Wed May 13, 2020 4:05 pm +1 Measure tool could be really helpful :)
Thanks for your input. We'll keep monitoring this thread for valuable user feedback!
arhi
Free version of netfabb is awesome for measuring features on the mesh. Having that functionality inside S3D would be useful, not a priority really as so many mesh tools already have it, many other things lacking in s3d that are much more important and much more related to actual slicing.
Embed M117 codes into G-Code
open source and unlicence
CaesarDGreat
Please add a measurement feature
kingmokex86
Yes this would be a very useful feature to add!
parallyze
arhi wrote: ↑Thu May 14, 2020 12:16 pm ...not a priority really as so many mesh tools already have it, many other things lacking in s3d that are much more important and much more related to actual slicing.
+1
Actually I'm still trying to figure out _IF_ I ever missed a measure tool inside S3D. I mean... it shows the objects size, so conversion mm/inches is usually no problem.... any real world usage example for this, why would I need to measure a hole inside an object inside the slicer?
boatanchors
+1 for me, too. Thanks!
