m.savazzi
Crazy issue - BLTouch and not able to print
I have this weird problem is driving me crazy:
1) Bed perfectly aligned (cold) and leveled (sheet of paper)
2) I can perform a BLTouch bed level and works
3) I prepare the print with a G29 (auto bed level) after the initial G28 (homing)
AND the hot end is so far away from the plate that it does not print :(
I've checked the Z stop and is ok
Z offset is 0 (checked with the G28 Z and G1 F60 Z0) and fine with the paper.
This is driving me nuts.
In additional issue is that I've calibrated the bed hot and now when cold the AutoLevel fails as the Z Stop is activated before of the BLTouch
The printer is a Zonestart P802QR2 and the bed is an AnyCubic Ultrabase
Anyone has ever seen this issue? any suggestion or idea?
malaique
Re: Crazy issue - BLTouch and not able to print
I am facing the same issue. Did you find a solution?
Thanks
m.savazzi
Ouch! I'm sorry for you.
Right now I've not found a solution :(
I have to try to remove the springs and fix the position
