airscapes
Re: multiple process printing - start/stop printing at height in mm vs layer
Fri Nov 08, 2019 11:44 am
This has been talked about over the years and it sure does not make sense how it is.
One work around is to multiply the layer number by the layer height and you will then have the number to plug in to the start and stop.
For instance if you want to change infill at layer 30 and your layer height is .3 then .3mm x 30 layers = 9mm.
One of the nice things about he metric system.. :D
