TopHATTwaffle
4.1.2 Start Points Not Consistent
In 4.1.2, the layer start points option is not working correctly. In 4.1.1 they do work correctly.
Both versions are using the same profile to slice the same model. The start point is set for the X0 Y300, so the back left of the bed on my CR10. On the 4.1.2 slice, the arrow is pointing at the start point for the feature in the bottom left of the part. This start point is completely wrong.
Looking at the 4.1.1 slice, this is the expected place for the layer start.
Factory file is attached as well for troubleshooting purposes.
TESTING_STARTS.factory
(15.09 KiB) Downloaded 158 times
