alexzogh
Raft on only one part?
I'm trying a multi-part print, but only want a raft on one of the parts. I set up two processes, one with a raft selected, and one part (staircase) with the raft and 3 other parts with the raft deselected. It seems no matter what I do, it prints a raft under all four parts. Is this a software bug?
Things I've tried:
changing the 'order' of the processes. increasing the distance between parts, sequential printing between the processes (2mm is the max I can do)
Factory file is too big to attach, but you can get it here:
https://drive.google.com/file/d/1I95bST ... sp=sharing
S3D-Chris
Re: Raft on only one part?
Try reducing the raft offset from part value and make sure your parts are spread out far enough on the bed to make sure they do not share additions.
twofirstnames
Thank you S3D Chris! I've been struggling with this for an hour.
Solution for all: "make sure your parts are spread out far enough on the bed to make sure they do not share additions"
