Totoleheros
Dual extrusion different infill percentage
Sat Feb 08, 2020 5:11 am
I need to do a dual extrusion printing but with two distinct infill percentages (100% on the primary and 30% on the secondary extruder). How can I achieve this? It seems that the Dual Ext Group use the same profile with no way to set the infill percentage for each extruder. Am I missing something there?
S3D-Chris
Re: Dual extrusion different infill percentage
Mon Feb 10, 2020 10:06 am
You can set a different infill percentage for each extruder! After using the dual extrusion wizard simply ungroup the process and set the infill percentage to what you want in each process.
sage2050
Mon Feb 10, 2020 4:19 pm
Just to piggyback on this, is there any way to use the dual extrusion wizard on a single model?
Mon Feb 10, 2020 5:11 pm
Not currently. You can certainly still setup prints for dual extrusion on a single model. You only need goto the appropriate tab in process settings and change the extruder assigned to the feature you're trying to alter the extruder for. Also, it's a good idea to first have changed the auto configure extruders option to select all extruders for printing. This way your extruders will both begin heating at the start of your print.
Totoleheros
Tue Feb 11, 2020 12:19 am
Got it, thank you very much!
Daniel-J
Tue Feb 18, 2020 2:31 am
Convenient ability to control the operation of each extruder.
