there have been many times when I wished I could change a perameter in the middle of a print.... I would like to see something where you could change a parameter... Say layer width. you would change the parameter tell it to change... the the current layer would be recorded.. print stopped and no gcode would be produced starting at the NEXT layer with the new parameter in force.
I do understand this is likely only to work with USB printing... but I mostly use that anyway
thanks for the consideration
