Unless you want to use multiple infill angles. Then the layers of each wall will be separated by the number of angles. .. which again makes them weak. (and also makes that first solid layer a royal pain to get pretty.jimc wrote:uncheck the box "random infill placement". if you do this the layers will all line up making a structure of walls.
