raylo32
different layer, different color - how to?
I have a dual extrusion machine makerbot dual clone. Is there a way to specify starting with base layers using one extruder/color then shift to the other extruder for the remaining layers? Is there a tutorial here as to how to do this? What I tying to do is print a flat base of one color and then a raised pattern coming up from it in a different color.
I found this tutorial that lets you specify different extruders for different elements, like skirt, raft, etc. But not by height or layer.
https://www.simplify3d.com/support/arti ... extruders/
Re: different layer, different color - how to?
You can easily specify different regions of your model to be printed with different settings, including which extruder is selected.
https://www.simplify3d.com/support/arti ... f-a-model/
