sgertsch
Select Models Bug
When models have the same name (case insensitive) they are all included in the process even though only 1 is selected for slicing.
Re: Select Models Bug
Would you please attach a Factory File showing this issue so we can all see exactly what you are experiencing.
File menu==>Save Factory File
TheBum
If you're just trying to print multiple copies of an object, it's better to use the Duplicate function (Ctrl-D on Windows, Command-D on Mac) than to import it multiple times. Each copy gets assigned a unique suffix that way.
