Hi Baron,
Trying to use your profile in Simlify3D to print on my Flashforge Dreamer. When I import an STL it only shows the bottom part. It looks like the dimensions of the axes is too small.
Any idea ?
thanks
Dirk
Can you post the STL, that would help if we were able to download it and try it out ourselves.pelgrid wrote:Hi Baron,
Any idea ?
thanks
Dirk
Sorry for the late reply. I have not had much time to visit forums lately.diptwa wrote:Hi there.
I purchased a Dreamer a week ago and am looking for ways to optimize it's performance - I'm relatively new to 3D printing but I'm already finding limitations in the flashprint software, and what you guys are doing with Simplify3D looks like some amazing work. I will probably take the plunge and buy the software.
I was wondering BaronWilliams, what steps have you taken to combat curling when printing with ABS on the Dreamer? What sort of things have you done to the settings in your dual extrusion profile? I couldn't get good results with the Kapton tape, and I'm trying the blue tape now with better results but it still curls at the edges. At this point I am just using the flashprint software with default settings, and my plate is absolutely dead level (it's easy on this machine because it is so well made and solid). I've seen people using hairspray, glass plates, various tapes, even making weird slurries out of acetone and ABS...
What do you do with your build plate on that machine?
I assume you're using the file: FlashForge Dreamer Dual Extruder 0_125a.fffpelgrid wrote:Hello, is this forum active.
I have a FF Deamer and would like to use Simplify. I managed to download the profiles.
The colors are changing, but nothing comes out priting. The extruder moves, but does not print.
Who can help me on this ? Can you share print screens how to set up correctly,
Many thanks
Dirk
Hi Doomkang, I haven't been using the posted profile for some time now. I have a newer version I'm using. I'll post it later here. I am not having any problems with dual extrusion. Your Dreamer must have the offsets for the two heads set wrong, or it could have the pulley type set wrong. These are firmware settings on the Dreamer itself. There's no way to control those settings, as far as I know, from Simplify3D. You'll need to use FlashPrint and the Dreamer's own built in configuration screen to fix these values if they are wrong.doomkang wrote:Hi Baron and thank you for sharing your settings for the FF dreamer. I tried it and it works nicely except for one thing (or maybe i've done something wrong) : if I print something with the right extruder, everything is ok but with the left one, the extruder goes out of the building plate (on the left). Any idea of the problem ?
Another question : have you already tried to use these settings for dual extrusion ?
Thanks again !
Ps : if there's a chance that any people from simplify3D is reading this post, may I suggest a software update including the flashforge dreamer in the settings ? I think that more and more people are using this nice small printer.
That's good to know. Did that information come from FlashForge directly?Jetguy wrote:FYI, the "reason" for setting 80% of stepper current for PLA is to reduce the motor heat. Since the extruder motor is coupled to the main mounting bar that is supposed to cool the thermal barrier tube of the extruder and since the Dreamer is enclosed, the entire cooling system is not as effective. As such, PLA which has a low glass transition temperature can become soft passing through the filament drive section and buckle or other problems if the stepper motor is run at 100% current in a closed environment.
So yes, the 80% current for PLA makes perfect sense.
