erichardson1978
Delayed Start
I want to start a print tomorrow at 4:00am. Is there a way to do this with the funmat HT?
ByteSlinger
Re: Delayed Start
In theory you could add G-Code to the very start of your start code that says something like:
G4 S60
S = Seconds, so if you wanted your print to start at 4am and you were planning to start your print at 10pm, you'd add:
G4 S21600
Not all printers recognise 'S' so if that doesn't work you'll need to use 'P' which is milliseconds instead
