I've read that people use a piece of paper to do that and other use gauges. In the last case, which gauge would I have to use for a 0.4 mm nozzle, 0.2 mm? And when I print with a layer height of 0.3mm for example for the first layer, does it mean that the nozzle would be at a height of 0,3mm exactly or 0.2+0.3 mm if I level with the gauge?
As you can see I am bit lost about it and I would thank any help!!
Kind regards
