lutcho
Preview mode window does not fit screen
I just installed 4.1.2 on a laptop running Ubuntu 20.04.2. I previously used the software only under Windows.
All is fine until I click on "prepare to print" to open the preview window.
The new window is higher than the screen resolution and the speed controls and exit button are not visible. If I want to leave the preview mode, I have to 'TAB' through the controls until the focus is on the exit button and then press the space bar.
This window does not have a resize or maximize button, so I can't edit it's height.
Although this works for the exit function, I just can't change anything on the animation controls.
Any hint?
S3D-Rick
Re: Preview mode window does not fit screen
Could you post some screenshots of the behavior you are seeing?
What is the vertical resolution available to your Ubuntu desktop?
The minimum vertical window size of the preview window is 760px.
