Nomnomnom
Flashforge Dreamer. Recently updated firmware
Hey guys. I updated my printer firmware and flashprint to the latest version last night. Files slice and print without any hassle in flashprint. Now when I slice a file in S3D, I still send the generated g-code to the printer through flashprint, but now after heating completes, the platform raises only a little, then the printer freezes and restarts. Sometimes it doesn't even make it that far. After the homing operation, the head may even move approx 30mm toward the heating position and then freeze and restart.
Any help is appreciated.
KeyboardWarrior
Re: Flashforge Dreamer. Recently updated firmware
Does printing over SD card work?
Nomnomnom
I haven't yet as I just got it working again with usb so haven't had a need. I shall try to send the job via SD card next.
narenpatel
I just got my new dreamer this week and the 1st thing they have you do is update the firmware. In doing so I have the same problem. did you figure out what was causing the issue for you ?
lucidpsykosis
Hey y'all :) First post here...
I just downloaded S3D this morning, found out there's a FW update as of lately...where do I find that file?? I got one from someone in a different forum, which was dated back in August, I think. Anywho, when I try to print from the big button that says "Print from USB", the print box shows up, but the progress bar doesn't move. The status doesn't move. Any ideas?
