cityshaker
Re: Cannot Activate New S3D Lisence
I'm also having the same problem today.
Billzilla
waynejacobsen wrote: ↑Fri Dec 17, 2021 11:52 am Any workaround or fixes?
Get Prusaslicer or Cura.
Problem solved.
truegret
Same issue
Uanble to connect to the activation server.
Please ensure that you have an active
internet connection prior to activating.
I removed one of the assigned licenses to the MacOS machine (connected to my printer), uninstalled, reinstalled Simplify3d-4.1.2, error continues. Contacted support. No response.
TMK112
same error messages as all, just paid and tried to use software activation server not allowing, says I don't have Internet connection, but I'm using same internet to post this exact message, did I just waste 150?
cnd
The issue on my Mac turned out to be an old certificate bundle file. Here's the "history" of steps I took that fixed it for me:
115114  Jan 27 09:46:15  cnd@/Users/cnd/cd/Downloads/un  curl -k -L -O 'https://curl.se/download/curl-7.81.0.tar.gz'
115116  Jan 27 09:46:30  cnd@/Users/cnd/cd/Downloads/un  mkdir c
115117  Jan 27 09:46:31  cnd@/Users/cnd/cd/Downloads/un/c  cd c
115118  Jan 27 09:46:36  cnd@/Users/cnd/cd/Downloads/un/c  tar xvfz ../curl-7.81.0.tar.gz
115119  Jan 27 09:46:56  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  cd curl-7.81.0/lib
115122  Jan 27 09:46:59  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  ./mk-ca-bundle.pl
115130  Jan 27 09:48:33  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  cp ca-bundle.crt ~/Downloads
115151  Jan 27 09:52:19  cnd@/etc/ssl  cd /etc/ssl/certs
115155  Jan 27 09:52:35  cnd@/etc/ssl/certs  sudo cp -a ~/Downloads/ca-bundle.crt .
115157  Jan 27 09:52:39  cnd@/etc/ssl  cd ..
115160  Jan 27 09:52:50  cnd@/etc/ssl  sudo mv cert.pem certo.pem
115161  Jan 27 09:53:02  cnd@/etc/ssl  sudo cp -a certs/ca-bundle.crt  cert.pem
Reckerke
It was tough to follow your instructions not being that great with the CMD prompt but I muddled my way through this and it worked for me after updating to 4.1.2. I ran into problems at the following step:
Receiving the following error:
cp: ~Downloads/ca-bundle.crt: No such file or directory
Ultimately I pushed through and manually typed the directory in full after searching it out in Finder and it worked like a charm. About 45 minutes of learning to use the command prompt and 2 hours of reading the forums and I am back online after updating the program.
:D CND's Solution (although not quite as cut and paste for me as I would have liked) is verified as of 06 March 2022! :D
MAC OS Mojave 10.14.6
Thanks!
aerodan
This post should be stickied. It literally saved my project from being late! Thank you thank you!
AD
cnd wrote: ↑Sat Jan 29, 2022 12:36 am The issue on my Mac turned out to be an old certificate bundle file. Here's the "history" of steps I took that fixed it for me:
ajinop
do you have any additional info, my terminal skills are rather weak?
ajinop wrote: ↑Sun Mar 20, 2022 6:24 pm do you have any additional info, my terminal skills are rather weak?
Contact support. They can walk you through it.
cityshaker
Having this problem again. Support are you listening? What can I do?
