Hi
I'm Just starting to use the software, and everything seems to be looking good, except when my printer starts to print circles, like bolt holes or posts. Straight lines and in-fills, the print speed is like normal, but when the printer needs to print anything curved it slows down to a crawl, very slow. I know it's has something to do with the gcode file from Creator, because the same print from Slic3r are fine and have normal performance.
Obviously this has to be something in the default configuration. Can you make some suggestions on what I should try and adjust?
Thanks
Anthony
