A frustrating and unwelcome change to how model scaling works. Took me a bit to figure this out. V4 always held the model scaling values. I set my x/y to 100.8% and it is nice to have a visual reference that the model is set to that. It now changes back to 100%, but the model retains the new size.
Yeah, that's a major PITA.
I won't be using V5 for production parts until that's fixed. I scale everything for dimensional accuracy and I NEED to know where things are at. Plus, you can't just reset scaling - you have to reset ALL transforms so if you parts are located on the bed ... too bad.
Make scaling stick, and put a reset button on scaling alone.
This is a significant issue for me and the app as I heavily rely on it retain that information vs being reset.
1. Using the input field change the Rotation value or Scale %
2. Use one of the new gizmo tools at the bottom of the screen to Rotate or scale
3. All of the values will be reset
Yes please fix! retain the percent to what it was set to. and not reset back to 100% after it has been deselected and selected again.
need to know if a part was scaled appropriately to account for cooling shrink factors.
