RoboDLC
Select Models crashes V5
Sometimes.
Put two or more models on the build plate.
Edit process settings
select one of the models and no other.
OK
Prepare to print.
Sometimes S3D crashes out
When it does, all build plate models and even the profile is forgotten and reset to something else.
OS: Windows 10 pro on i5 motherboard with 32GB RAM.
be well,
DLC
D. Clark
Robotics and sensors engineer
And lots of other stuff for fun.
bolsoncerrado
Re: Select Models crashes V5
Which OS?
I tried to reproduce this but haven't had any luck. Do you have a factory file that you can share? Is it easily repeatable?
bolsoncerrado
You tried to reproduce this on which OS? OP does not even state it! LOL
RoboDLC
S3D-Jason wrote: Mon Dec 19, 2022 9:44 am I tried to reproduce this but haven't had any luck. Do you have a factory file that you can share? Is it easily repeatable?
Select Models was a red herring.
I put up a couple of factory files for a similar project that also had crashes. It seems to be related to the smaller part.
be well,
DLC
D. Clark
RoboDLC
bolsoncerrado wrote: Mon Dec 19, 2022 1:28 pm You tried to reproduce this on which OS? OP does not even state it! LOL
ooooh, aren't we feeling superior today!
be well,
DLC
D. Clark
Aotrs Commander
I will also report I have had intermittent crashes when hitting prepare to print. Not consistently, but on more complex models; over the course of today, during which I installed and have begin experimenting, it has crashed to desktop suddenly about four times, I think?
A couple of times, after the crash, restarting didn't sem to work, I had to open Task Manager and kill the process before starting again.
I'm attaching a file which crashed twice in successions before I was finally able to get it to go to print.
Operating system Win 10, 64 bit.
AMD Ryzen 5 1600 Six-Core Processor 3.20 GHz; 32.0 GB RAM.
FV622 Stalwart.factory
(463.71 KiB) Downloaded 186 times
I believe this same factory file was also posted in another thread. It now slices correctly in the latest V5.0.1 software, so update to that version and the problem should be fixed!
