Gdruckt
V5 and Repetier Server
Question regarding connecting to repetier Server?‘
Is this possible?
Want to export an gcode direct from simply to repetier
Thank you
Re: V5 and Repetier Server
I know many customers are already doing something similar by just adding a single line in their post processing script. That way the build files with by synced with Repetier server each time you export them.
The process is pretty easy, but the exact command may different depending on whether you're running Windows or Mac/Linux.
Gdruckt
S3D-Jason wrote: ↑Wed Dec 21, 2022 6:57 am I know many customers are already doing something similar by just adding a single line in their post processing script. That way the build files with by synced with Repetier server each time you export them.
Ism using a mac.
Can you help me?
Is there a how to guide ?
Thank you
Khaos
There is a tutorial here: https://www.repetier-server.de/using-si ... er-server/
It's in German. But Google Translate will help you ;)
