DrD
[FIXED] V5 Crashes when slicing model that has supports
I have a model to which I've added supports (from the build plate only) and V5 crashes every single time that I go to slice the model.
Please take a look and let me know what's happening. Thanks.
D.
Supported Fan Shroud.factory
Crashes when supports are added then model is sliced.
(329.54 KiB) Downloaded 135 times
Re: V5 Crashes when slicing model that has supports
It's possible this issue might be related to coasting or wiping, and not the support structures. If I turn off coasting and wiping, it seems to slice correctly.
kyleamorgan
I'm getting a lot of random crashes too when slicing. (latest Mac OS, M1 chip). Sometimes it works, sometimes it doesn't.
DrD
S3D-Jason wrote: Tue Dec 27, 2022 7:09 am It's possible this issue might be related to coasting or wiping, and not the support structures. If I turn off coasting and wiping, it seems to slice correctly.
Interesting. Could you please log that as a bug? In the meantime, turning off either coasting or nozzle wipe allows the model to be sliced.
I shared it with the team, so they are already looking into it! Thanks for reporting it!
This file now slices correctly in our latest Version 5.0.1 update. Thank you for your help reporting the issue!
