heinrichplatau
Simplify3D v5 - Can't switch between different printers (processes)
Hello,
since upgrading to simplify3D v5 I have big problems with switching between different printers to prepare the accurat g-code files for each one.
In v4.1.2 I've created two different processes. One for my own build printer (Build Size: 400x380x320mm) and for my second printer Raise3D Pro3 Plus (300x300x600mm)
While preparing the model I just choosed my prefered printer by clicking the process, then clicking edit process and then clicking ok in the window with all print parameters.
After this the software automatically resized the shown printer build volume (print chamber).
In V5 this isn't possible any longer.
Can anyone tell me please - is this my fault ? Did something change? How do I switch between printers in the software?
Or is this a bug ?
Thank you!
Re: Simplify3D v5 - Can't switch between different printers (processes)
Please see a similar response here:
viewtopic.php?p=63754#p63754
In short, open your process and click Save as New to add it into the S3D profile database. That is the intended place to store permanent printer configurations.
