jbenw07
[FIXED] Delete Key Does Not Remove Selected Models V5
Minor issue - Selecting a model and pressing Delete does not remove the model as it did in V4. Backspace will delete selected models, but not the Delete key.
wolfpackmars2
Re: Delete Key Does Not Remove Selected Models V5
I ran into this as well. The keyboard shortcuts can be changed from the tools menu.
I'm curious if there was a reason that "Backspace" is the new default instead of "Delete". If I change the shortcut to "Delete", I want to avoid any potential issues that may cause.
EDIT: Just tried changing the keyboard shortcut from the "Keyboard Shortcut Editor" and I find that I'm unable to actually change the shortcut. When I choose "Edit Shortcut" I get a prompt for "Enter the new keyboard shortcut" but it doesn't register any keypresses.
Simplify3D Version 5.0.0 Linux Mint 21 (Ubuntu 22.04)
3dbybrunolopes
Yeah...tried that, and you can't change the shortcut key
dsiegfried
I ran into that as well. It's frustrating, I don't know why they changed it.
I tried editing the command for removing the model and it will not accept single key presses.
It will only accept Crtl+ another key. This needs to be fixed.
bolsoncerrado
+1 to bring back the DEL key to delete stuff!!! (macOS vote)
M4nusky
+1 to bring back expected UX
We just released Version 5.0.1 which now allows both the Backspace and Delete keys to be used to remove a model, just like V4.
https://www.simplify3d.com/products/sim ... ase-notes/
Re: [FIXED] Delete Key Does Not Remove Selected Models V5
Thank you. It's a silly thing but you get used to certain keystrokes!
